Farmall H Generator Wireing
Bob R
06-10-2001 12:21:44
Hi all ,
I am hooking the generator back up on my 51 H that has voltage regulator .
Looks like a short wire from the field terminal on the gen. goes to ground . I cant tell if that wire should be hooked up or not .
The long wire from field gen. to field reg . is hooked up . Along with every thing else
I am positive about everything else but that short "field" ground wire.
I dont want to hook it up and fry something . Reg. is new dont need another one yet ...
Will polarize when done . . .
Thanks
Bob Rascoe
The Red
06-10-2001 12:25:16
 Re: Farmall H Generator Wireing in reply to Bob R, 06-10-2001 12:21:44
Bob the wire from the field generator post to the field regulator on the light switch is adequate. I have never grounded the field generator post to the frame.
Bob R
06-10-2001 12:38:34
 Re: Re: Farmall H Generator Wireing in reply to The Red, 06-10-2001 12:25:16
Hey Red ,
I looked up in an old motors manual and found that if you short out the field gen. terminal to ground it overides the voltage regulator and you end up overcharging thr battery .
They showed putting a condensor on the "A" terminal and ground to reduse noise .
Saw this as I read you reply .
Thanks for the speedy reply
I have been mowing my lawn with the "H" with a three point Saginaw hitch and six foot Woods mower .
Mow about 3 acres and its GREAT . Dont mess up the lawn with weaterworn "turf" tires . Tires are 15.5's about to rot apart . My "turf" tires .
Thanks again Red ! ! !
LOU
06-10-2001 16:24:11
 Re: Re: Re: Farmall H Generator Wireing in reply to Bob R, 06-10-2001 12:38:34
YO GENTS,,,LOOKING TO DO THE SAME THING,,,MOW SOME MANICURED LAWNS WITH AN "H",,WHAT SIZE AND TYPE MOWER DO I NEED????,,WOODS SOUNDS LIKE THE BRAND I NEED,,ALSO A SAGINAW,,,,EVERYONE WANTS ME TO PULL A OLD STYLE "SHREDDER",,OR A "SICKLE BAR",,,WOULD LIKE TO USE WHAT THE CITY WORKERS USE,,,,LOOKS NICE,,,,MOWING GRASS, SOME WEEDS,,NO ROCKS, STUMPS, ETC,,
THX
The Red
06-10-2001 12:43:16
Bob how do you like that Saginaw hitch?
