Floorstands
Order Farmall Cub Parts Online
'48 Cub
Bill VanHooser
06-15-2001 09:51:48
I am planning to replace the gasket on the steering gear base housing. The problem is I don't have floorstands. I've looked around at some auto stores and most only go up to a height of 25". This appears to be a bit on the short side. The service manual has pictures of stands with extensions that bolt to the sides of the casting. Are these home made or can you buy them? Any recommendations will be appreciated. Bill
John
06-15-2001 10:38:14
 Re: Floorstands - '48 Cub in reply to Bill VanHooser, 06-15-2001 09:51:48
third party image
Bill, you can see the stand in this photo.
John
Bill VanHooser
06-17-2001 18:42:20
 Re: Re: Floorstands - '48 Cub in reply to John, 06-15-2001 10:38:14
Thanks, John. That's a nice set-up you have. It gives me some good ideas. Nice shop too.
John
06-15-2001 10:34:55
Bill, I made mine using some scrap pieces of 4" by 6" treated lumber and some casters with 4"diameter wheels rated at 1000 pounds each. The assembly simply bolts to the front implement mounting pads. There is a crossmember that can be used to raise or lower the front end with a jack. It works very well. If you like, I can send you a photo on Monday.
John
