Farmall H trans fluid changeout
Bradley
06-16-2001 09:31:32
I have a Farmall H and I would like to change the transmission fluid. I know that the fluid is a 90weight and is 6 gallons but will all the fluid drain out of the rear plug or do I need to take off the front small plug to get all 6 gallons out. And should I put kerosene in the trans to get any solids out of the trans case? THis might cause the trans to leak if gaskets are worn. Thanks in advance.
The Red
06-16-2001 09:42:55
 Re: farmall H trans fluid changeout in reply to Bradley, 06-16-2001 09:31:32
Bradley you definitely want to remove that front plug also. You will get a quart or 2 of 90 weight from there.
Also on the belt pulley. The transmission slings 90 weight into the belt pulley assembly. It is designed to hold about 1/2 quart in the lower section of the assembly. Remove the 4 face bolts and tap the pulley out about 1/4 inch. The face casting will also come out with the pulley. You will get a good 1/2 quart or so of 90 weight and water. Condensation collects in the belt pulley assembly being the highest point on the transmission. Save 1/2 quart to a quart of the new 90W to refill the belt pulley assembly. Filler plug is on top. Don't worry about overfilling. The excess will drain back into the transmission.
