Where to buy obsolete I-H plow shares
Alan Dewsnup
06-22-2001 17:31:09
Does anyone have an idea where I could locate a set of obsolete I-H P/N OC 582 51 1X SOLID PLOW plow shares. I still use this type share on my 2 bottom 2way I-H plow. I am very hopeful that someone can help me out. This type of share is wider than the new style, is pulled onto the plow frog with an eye-bolt then bolted to the plow structure. It is similar to the share found on the tumble bug type plow but is not interchangeable. please drop a note if you can direct me. Regards, Alan Dewsnup (UT)
Guy Fay
06-23-2001 11:36:14
 Re: where to buy obsolete I-H plow shares in reply to Alan Dewsnup, 06-22-2001 17:31:09
If you're local Case dealer can't help, you may want to give these guys a try:
http://www.farmerbrownsplowshop.bigstep.com/
