Farmall Serial Numbers
Brett West
06-25-2001 18:51:14
I just bought what I thought was a 1947 Farmall H. Now that I have looked it over, I believe it to be a 1944 model. The serial number plate on the left hand side is gone. The number on the front right on the engine is FMH-170309. Were the tractor serial number and the engine serial numbers the same? The operators manual makes me wonder. Any info would be appreciated!
swamp yankee
06-25-2001 19:16:26
 Re: Farmall Serial Numbers in reply to Brett West, 06-25-2001 18:51:14
On a Farmall H the chassis and engine numbers match.This is not true of all IH tractors.My H is #171375,pretty close to yours.The casting dates should end with the letter N,confirmg that the rest of the tractor is the same as the engine.
Courtland
06-26-2001 10:40:13
 Re: Re: Farmall Serial Numbers in reply to swamp yankee, 06-25-2001 19:16:26
are you from new england?? my father in-law calls me swamp yankee...
swamp yankee
06-26-2001 15:27:31
 Re: Re: Re: Farmall Serial Numbers in reply to Courtland, 06-26-2001 10:40:13
Absolutly.SE Mass. to Narrow it down.
Ludwig
06-26-2001 15:42:02
 Re: Re: Re: Re: Farmall Serial Numbers in reply to swamp yankee, 06-26-2001 15:27:31
Swamp Yankee, where you at? I live in Gardner. I work in Marlboro.
Since I'm from Maine, livin here we call "doin time away" you do your time away and when you move back it seems even more like living in paradise.
"They're TURN SIGNALS DANGIT! You use them when you TURN!!!"
swamp yankee
06-26-2001 16:26:54
 Re: Re: Re: Re: Re: Farmall Serial Numbers in reply to Ludwig, 06-26-2001 15:42:02
Norwell, down on the south shore,with all the yuppies. I have ties to Downeast also, know exactly what you mean.Did you go to the show at Orange this weekend? I had my H there.
Ludwig
06-26-2001 16:36:12
 Re: Re: Re: Re: Re: Re: Farmall Serial Numbers in reply to swamp yankee, 06-26-2001 16:26:54
dang it, I didn't even know there was a show in Orange! Right in my backyard. Not like I was doing anything either.
sy
06-26-2001 17:17:07
 Re: Re: Re: Re: Re: Re: Re: Farmall Serial Numbers in reply to Ludwig, 06-26-2001 16:36:12
Too bad we didn't hook up earlier.There is a show in Pepperell MA July 8 at the town field, jct. of rtes.111 and 113. Come to the IH Collectors tent ad ask for Gary. I'll be there with my H. Hope to see you.
Brett West
06-25-2001 20:33:08
Thanks! I'll check the casting dates (once I uncover them). In the number, the second zero looks kinda like a Q. Any chance they could have done an overstrike? All I can figure is it must be a zero but it does look slightly different than the first one in the number.
It is interesting that our tractors are so close in number...I wish there was a way to track down their history by serial number. I had an antique Colt SAA six shooter that I had a serial trace done on. It told me where it was originally shipped to and sold the first time.
swamp yankee
06-26-2001 15:39:35
 Re: Re: Re: Farmall Serial Numbers in reply to Brett West, 06-25-2001 20:33:08
I am certain that the 2nd 0 is a 0. Our tractors were probably made about 2 weeks to 1 month apart.It was shipped to New England. I would be interested in knowing what your casting codes are, just to compare them.You can email me direct if you want to.
Brett West
06-28-2001 17:34:07
 Re: Re: Re: Re: Farmall Serial Numbers in reply to swamp yankee, 06-26-2001 15:39:35
Swamp:
I finally found them after much searching. They are as follows:
6-17-N
6-21-N
5-26-N
The book says that they were done in DD-MM-Y format but these would indicate a MM-DD-Y format. Ever heard of that before on a 1944?
