Gear up IH-C to rake with
Blackangus
06-26-2001 04:42:04
Just wondering if I can put 38" wheels on my C to gear it up in 3rd for raking hay.Thanks for any information or any other ideas.
Haas more info
06-27-2001 06:00:44
 Re: Gear up IH-C to rake with in reply to Blackangus, 06-26-2001 04:42:04
The parts book lists and optional third gear for 7 MPH speed. See my reply to Dick Davis below.
Haas
06-26-2001 17:19:17
According to my manual, the C goes 5 MPH in third with 9X36 tires. Going to 11X38 tires will only give you about 10 percent more or about 5.5 MPH. Seems hardly worth the effort and expense.
Dick Davis
06-26-2001 21:19:40
 Re: Re: Gear up IH-C to rake with in reply to Haas, 06-26-2001 17:19:17
"Hardly worth the effort or expense?" Gee Haas, very little, if anything, we talk about here survives that rational.
Haas
06-27-2001 05:58:27
 Re: Re: Re: Gear up IH-C to rake with in reply to Dick Davis, 06-26-2001 21:19:40
Well guess that's true. I see the C parts book lists an optional 30 tooth third gear (in place of the normal 35 tooth) for 7 MPH speed. If you could find one of those gear sets, that would make a difference. You also have to have a new sliding gear for third and 4th speed with 31 and 37 teeth instead of the normal 26 and 37. Changing the transmission would make more since that the tires and wheels and probably would not cost any more.
Blackangus
06-27-2001 19:57:06
 Re: Re: Re: Re: Gear up IH-C to rake with in reply to Haas, 06-27-2001 05:58:27
Thanks Haas and Dick Davis.I just got in the house.Thank you for your information.I thought maybe taller tires would make a difference but I see what your saying.I never knew they had a 7 mph 3rd gear.I'll keep my eyes and hears open,maybe I'll get lucky and find this set up some where.Thanks again.
Andy Martin
06-28-2001 09:11:23
 Re: Re: Re: Re: Re: Gear up IH-C to rake with in reply to Blackangus, 06-27-2001 19:57:06
I rake with a C in 4th gear, throttled back. This is with a side delivery rake.
Haas
06-27-2001 20:17:19
The IH part number for the 7 MPH gearset is 359 977 R91. It consists of two gears, part number 359 978 R1 (The 30 tooth third gear) and part no. 359 979 R1 (the 31 and 37 tooth sliding gear). If you are serious, you might try the Case/IH dealer. They might still have one in the warehouse.
