F-14 is it worth a try
big al
06-29-2001 10:08:19
I found an old F-14 that will be sold at auction tommorow. It is really rough but is all there. There is a lot of spare motor parts that sell too but the guy doesn't know if they are for a 12 or a 14. Should I buy it if it goes real cheap even if just for parts Thanks
Bill B
06-30-2001 04:21:03
 Re: F-14 is it worth a try in reply to big al, 06-29-2001 10:08:19
The 12 and 14 are very similar, and the engines are almost the same. the 14 has 2 bolts holding the valve cover, like the late 12, and the 14 has a different breather on the engine. the 14 also has a higher steering, and longer brake handles, and sometimes foot brakes. Other than that, they are about the same. The internal parts of the engine and trans are the same I think. I have a 12, and they are a nice little tractor.
Charlie
06-29-2001 12:10:35
If it looked fixable and went for a decent price I'd buy it if it was me. I have one and they are a pretty neat little tractor. There are lots of parts available and almost all F12 parts fit the F14 - a few are different.
brianh
06-29-2001 11:14:37
The engines for the 12 and 14 are the same. The only difference is that the 12 engine runs to 1400 RPM and the 14 is governed at 1650.
MikeH-Tx
06-30-2001 16:40:44
 Re: Re: F-14 is it worth a try in reply to brianh, 06-29-2001 11:14:37
The late F12 engines are the same as the F14, but not the early ones. My 35 has a different crank, different piston rods, different oil filter base, etc than my 36 parts tractor. Even earlier, Waukausha engines were used and were completely different.
Flyin Faarmall
07-01-2001 21:41:11
 Re: Re: Re: F-14 is it worth a try in reply to MikeH-Tx, 06-30-2001 16:40:44
whats the diff between the crank,rods,pistons??just wondering
Jason
07-04-2001 11:49:34
 Re: Re: Re: Re: F-14 is it worth a try in reply to Flyin Faarmall, 07-01-2001 21:41:11
One thing I noticed is the pistons on later tractors are taller than the earlier, Mike is right they changed some of the internals ( at least the pistons)between the '35 and'36.
