Pulled the B today....
1PWRFULH
06-30-2001 13:40:08
and had the most fun of my life! Boy, that is some fun stuff! Never pulled before either. I had one set of weights on the rear and one set on the front and she weighted 2,644. I think I either gotta get some off to be in the 2,000 class or put my other set on the rear which will get it close to 3,000 but in the same class. I gotta have at least some weight on it though for doing stuff around here. Put her in first and it sounded right with the straight pipe and wide open. The thing sounded the same when I hooked it up and right when it started spinning. The sled didnt even phase the motor so I think I can get along with another rear weight set and still be in the same class. Well just thought I would share my pulling experience with you. Take care
RC
Red Dave
06-30-2001 16:25:28
 Re: Pulled the B today.... in reply to 1PWRFULH, 06-30-2001 13:40:08
Sounds like lots of fun!
I don't know if you can get below 2000lbs though. I put my B on a scale one time. No wheel weights, no water in the tires, steel pressed wheels not cast, 3/4 tank of gas. 2140lbs before my butt was in the seat. I can't swear to the scale's calibration, but the pullers weren't screaming so it was probably close.
The Red
06-30-2001 14:46:59
That sounds GREAT! Have fun!!
