Carb float
Bottom D
07-01-2001 08:18:14
The float on my 1020 did not have room to move freely. So I took some off the outside witch seamed to be a coating of some sort that was bubbled up. Now I have the bear wood showing. Should I coat this? With what? Thanks in advence. B.D.
Bob Kerr
07-01-2001 16:09:08
 Re: Carb float in reply to Bottom D, 07-01-2001 08:18:14
You can coat the float with gas tank sealer. Originally they used shellac on cork floats which works fine if you don't have ANY alcohol in the fuel. Alcohol will dissolve shellac. If you bought a new float for your 10-20 I know exactly what you mean about the bubbles. The new float I got had bubbles and it caused the float to hang up at the end opposite of the brass tang. I took a file and filed the coating until it cleared.Also throw out the directions for seting the float! It will run way too rich if you set it to the spec they give. Look on the inside of the carb fuel bowl and you will see a groove cut into the inside of the bowl all around. Set the end of the float to the groove.Works perfect! It will start easy and be easy to adjust the carb when you have it running. I have a feeling they cut that groove for the guys to use as a guide when putting the carbs together on the assembly line.
justin
07-01-2001 08:40:09
What you need to do is probably replace the old cork float with a new brass float. Branson enterprises from rockford illinois has them.
Bottomd D
07-01-2001 10:54:52
 Re: Re: Carb float in reply to justin, 07-01-2001 08:40:09
Justin'The operator said there is no listing for Branson Interprises in rockford Illinois. Do you by chance have their number? THANKS B.D.
justin
07-01-2001 11:12:35
 Re: Re: Re: Carb float in reply to Bottomd D, 07-01-2001 10:54:52
Here is their info:
Branson Enterprises
7722 Elm Ave.
Machesney Park, IL 61115
815-633-4262
