Order Farmall Cub Parts Online
Cub clutch adjustment
Bayou Dave
07-06-2001 13:40:20
I have my friends yellow and white cub in my shop trying to adjust the clutch. I have the inspection plate off under the bell housing, the cotter key, and pin out of clutch shaft where it attaches to the throw-out bearing, and the clutch shaft loose. I can not turn the clevis at the end of the shaft. Is there a lock nut that is preventing it from turning? Not that I can get my hand in the hole, but I don't feel any threads on the shaft. Do I make the adjustment there, or do I adjust the 3 clutch dogs the throw-out bearing engages?
John
07-06-2001 17:54:54
 Re: Cub clutch adjustment in reply to Bayou Dave, 07-06-2001 13:40:20
Dave, the release bearing should be adjusted to within 1/8" of release fingers. This adjustment is made at the clutch pedal. Look for a bolt that allows you to slide the pedal for adj.
John
Chris B.
07-07-2001 00:47:22
 Re: Re: Cub clutch adjustment in reply to John, 07-06-2001 17:54:54
In Bayou Dave's case, the clutch ought to be adjusted at the pedal. However, on the older Cubs (like mine) the freeplay is adjusted at the clevis in the torque tube. Chris B.
Bayou Dave
07-07-2001 12:30:06
 Re: Re: Re: Cub clutch adjustment in reply to Chris B., 07-07-2001 00:47:22
I had a 49 model, many years ago, and thought I remembered adjusting it at the clevis in the torque tube. Thats why I was a little surprised when I couldn't get that clevis to adjust, and thought I better ask before I broke something.
Thanks again!
Bayou Dave
07-06-2001 20:39:40
Thanks, that makes sense, I will check it out and adjust.
