Postive or Neg ground on Farmall 400 and AC D19
Bill Porter
07-08-2001 15:34:59
Hi All, I replaced batt on both of the above tractors and
as there was not a batt in either one I put them
in hooked up as neg ground. But now both charge backwards or else both gen failed at once. Did I goof and they should have been postive ground??
Thanks
Bill
Bill Porter
07-15-2001 09:27:52
 Re: Postive or Neg ground on Farmall 400 and AC D19 in reply to Bill Porter, 07-08-2001 15:34:59
Hey All, Thanks for your help, have changed cables and everything is working right.
Bill
Ryan - IN
07-10-2001 08:45:47
D19 is positive ground as well. I am a AC C & D17, so I am speaking from experience
Daryl
07-10-2001 08:11:06
Bill, The 400 would have a positive ground as it came from the factory. Many were converted to negitive ground when being converted to 12 volt and an alternator. Most alternators require a negitive ground. To convert to negitive ground requires the rewiring of the amp gauge and probably some wiring changes on the regulator & generator if that is still on your tractor. The starter will work either way.
Brian in MO
07-08-2001 21:13:01
The company I work for owns a AC-D15 it has a positive ground I would assume that a D-19 would also. At least if it was original and hasn't been changed.
Red Rider
07-08-2001 20:46:21
I changed my 400 Diesel to a negative ground. All you have to do to get your amp gage to read correctly is swap leads on you amp meter.
The Red
07-08-2001 16:35:22
Bill if nothing has been changed on the 400, I believe positive ground was the correct configuration. It was on the predecessor Super M.
