Farmall 100 steering box
Bill
07-08-2001 20:40:02
I need a steering box for a Farmall 100. Anyone know where I can find one? The steering wheel will turn almost half way around without turning the wheels. Makes cultivating rather difficult!
Haas
07-09-2001 05:12:22
 Re: Farmall 100 steering box in reply to Bill, 07-08-2001 20:40:02
I suppose you can only find a used one. If you can find one, you would want to rebuild it before you installed, so you might as well just rebuild the one you have unless the housing is broken. If you take it apart and put in new bearings, it will likely take out much of the play in the steering. Check the steering worm shaft bearing first by removing the big plug on the front of the steering gear. It's easy to replace and if worn will cause steering play.
