Farmall M front Bearings
Andy
07-09-2001 05:51:03
I have an "M" with a Trike front and the "Bolster Axial" on one side had a shot seal. I was able to hammer off the dust shield on the very inside..however I'm not sure how the seal comes off. The other side has a different seal so I assume they are replaceable..The side that's damaged had a more "Traditional seal Ring" (with a spring etc.) while the good side appears to have a metal ring (that the inside wheel bearing sits against) followed by three rubber rib rings which lead into the dust shield...
Anyone ever take on of these apart? Where can I get parts for it? Appreciate any help/comments..
The Red
07-09-2001 07:15:23
 Re: Farmall M front Bearings in reply to Andy, 07-09-2001 05:51:03
Give Ken Updike a hollar at 608-455-2411.
Jon with an M
07-09-2001 07:42:36
 Re: Re: Farmall M front Bearings in reply to The Red, 07-09-2001 07:15:23
When you call for the bearing and seal set you need the number that is stamped on one of the spokes of the hub. There are two different bearing sets. I just found this out.
