High profile or low profile
amy
07-16-2001 17:18:40
hey how do you tell if your farmall is a high or low profile tractor.
Red Rider
07-16-2001 21:43:20
 Re: high profile or low profile in reply to amy, 07-16-2001 17:18:40
Are you talking about High Clear models? On a standard Farmall the axle shaft that the wheel attaches to comes straight out of the rear end. On a high clear Farmall there is a gear case that bolts to the axle housing droping the axle shaft down 12 inches or so. If the front end is single tired the yoke is longer, If wide front then the spindles are longer.
bill
07-16-2001 18:01:43
longer spindles and taller rear wheels
happy tractoring
