Soda ash mixture
Bill from Tex
07-18-2001 12:39:53
Does anyone know a recipe for a hot tank bath using soda ash. I have a block for an A model that I need to clean up. Them mean ole EPA guys have made all the local grages quit using their tanks.
gene b
07-18-2001 18:02:43
 Re: soda ash mixture in reply to Bill from Tex, 07-18-2001 12:39:53
caustic soda is the stuff do you heed the mixing amounts this will get rid of the lime deposits pull the sleeves first to get a better job
Sven
07-18-2001 13:12:49
I'm guessing that you want to degrease the block?
What I've used is TSP (trisodium phosphate) in hot water or through a pressure washer. Works fairly well but not as good as a solvent. I think soda ash is sodium hydroxide also known as lye. This is commonly used in drain cleaners. I prefer TSP because its cheap. I wouldn't put this into a septic system.
Sven
07-18-2001 13:10:14
Haas
07-19-2001 05:27:59
 Re: Re: soda ash mixture in reply to Sven, 07-18-2001 13:10:14
Soda Ash is sodium carbonate, not sodium hydroxide or lye. Lye/sodium hydroxide is a much stronger caustic than is soda ash. Soda ash is commonly used to increase the ph in swimming pools. It is available anywhere swimming pool chemicals are sold, usually called "ph+" or "ph up"
Lloyd
07-19-2001 07:38:06
 Re: Re: Re: soda ash mixture in reply to Haas, 07-19-2001 05:27:59
Soda ash is mostly sodium carbonate, but don't get careless with it. At the concentrations you would use it at, it will burn you badly. It is especially bad to get in your eyes, and can EASILY blind you. It would be a really expensive tractor if it cost your eyes.
Haas
07-19-2001 09:36:29
 Re: Re: Re: Re: soda ash mixture in reply to Lloyd, 07-19-2001 07:38:06
Yes, you are correct, soda ash requires care in handling. Will cause skin burns if not washed off immediately. Serious if you get it in your eyes!!
