M with gas start runs on kerosene / Diesel
230,H,M,
07-18-2001 18:33:22
I need a primer on the gas start kerosene / diesel run engine on an M. Does the engine have an injection system like a diesel engine? Spark plugs ?? If the gas part does not work will the engine start when cranking with the starter?? I know where there is an M with this system but I am not very knowledgeable about the system (you can tell right).
Bob M
07-18-2001 18:57:46
 Re: M with gas start runs on kerosene / Diesel in reply to 230,H,M,, 07-18-2001 18:33:22
The M diesel is a unique motor. It is a true diesel engine with a standard diesel injection system, plus has a carburetor, spark plugs, etc as in a gasoline engine for starting. If the gas cycle of the motor does not work, the engine cannot be started with the electric starter - the starter does not have the power to spin the engine against the diesel compression. You can however pull start an MD - trick is to get the motor spinning fast enough for the diesel cycle to fire.
The gas-start IHC diesel is a good engine, but requires good maintenance and careful operation to insure reliable starting and long life
Haas
07-19-2001 05:15:59
 Re: Re: M with gas start runs on kerosene / Diesel in reply to Bob M, 07-18-2001 18:57:46
The starter on my MD will turn the engine in diesel mode, although slower than when in gas mode. It was not running when I got it, and could not get it started on gas. So I tried starting fluid and cranking on diesel. Two shots of ether later, it was running! Found I had a timing problem on the gas side, so I've only done the ether start twice, but it can be done.
