Farmall Super A's
bronco
02-25-1999 20:39:18
I'm thinking of purchasing a Super A, and I hear pro and con on that particular model Farmall. I now have a re- built Cub and enjoy it very much. The A would be used for dirt plowing, snow plowing and post hole digging chores. What are some thoughts and experiences ???
KIRK
04-12-1999 21:51:22
 Re: Farmall Super A's in reply to bronco, 02-25-1999 20:39:18
I'll have to agree with most of the others, the SA doesn't have a 3 point hitch. Although you can make a 3 point conversion pretty easily. I have a SA with a home built blade on front and it does light work very well. My "A" model has a 5' belly mower and I would'nt trade it or my SA for ten thousand Fords. As for posthole digging you may need a bigger tractor, but buy the "Super A" anyway and you will never regret it. You may lose interest in the Cub very quickly though.
JR
04-11-1999 14:01:40
If you want a tractor for plowing dirt ,snow,And post hole digging. I would get a Massey Ferguson 35 or a Ford 8N.They both have a regular 3pt hitch
JR
04-11-1999 14:00:15
If you want a tractor for plowing dirt ,snow,And post hole digging. I would get a Massey Ferguson or a Ford 8N.They both have a regular 3pt hitch
JR
04-11-1999 13:59:08
Harold H
02-27-1999 07:44:58
Bronco,
If you want to stick with IH, I would suggest you look at a International 300, 330, or 350 Utility with IPTO. A 3 point adaptor is easy to add to the two point hitch. They will do what you want and can be found for a resonmable price and are good tractors.
Harold H
HUB
02-26-1999 13:22:19
ANOTHER FACTOR TO CONSIDER IS LIVE PTO. IF YOU ARE GOING TO PAY FOR A NICE 8N, YOU MIGHT AS WELL CHECK OUT A MF 35 OR EVEN A 135 WHICH WOULD NOT BE MUCH MORE MONEY. THE BEST BARGAIN I HAVE HAD WAS A COCKSHUTT 540. SINCE IT IS A LITTLE LESS COMPACT, IT IS NOT AS POPULAR WITH WEEKEND FARMERS, BUT YOU CAN OFTEN GET A GOOD ONE FOR LESS THAN THE TRENDY TRACTORS. HOWEVER, IT IS DEFINITELY NOT AS COMPACT.
Fred
02-26-1999 12:30:59
You will find that the little SA will not be up to what you want it to do. It does not have a three point hitch which is very useful. Keep your Cub and look for a nice Ford 8N. It will do everything you just described.
keith
03-26-1999 16:47:23
 Re: Re: Farmall Super A's in reply to Fred, 02-26-1999 12:30:59
ford never made a good tractor 8n or other!
jr
04-11-1999 13:49:30
 Re: Re: Re: Farmall Super A's in reply to keith, 03-26-1999 16:47:23
I think The Farmall super A is not as good as a Ford 8n . The best tractor I have drove was a Massey Ferguson 35.The A has no 3pt hitch.
lc
02-26-1999 05:52:34
The super a is a very good small tractor. One drawback though. IF you buy it you won't like the cub so much anymore.
Jim
02-25-1999 21:21:35
As the proud owner of a Super A....Id say if you have much dirt and snow to plow...you need a bigger tractor...and the Super A doesnt have a 3 pt hitch...so youre going to be limited on post hole diggers.....but its a wonderful little tractor for a belly mower..or to plow gardens...
ddg
02-26-1999 04:16:26
 Re: Re: Farmall Super A's in reply to Jim, 02-25-1999 21:21:35
I've got both, when you get the SA, you'll wonder how you ever made it with a cub....DG
McClellan
03-02-1999 17:47:15
 Re: Re: Re: Farmall Super A's in reply to ddg, 02-26-1999 04:16:26
I was raised on JD & 8ns and never was on IH until I bought SA 2 yrs. ago. It came with 5 ft. belly mower, 3 pt. hitch conversion, and 5 ft. snow blade. Tne little SA never stops amazing me at what it can do. If you want a big tractor,buy one, if you want a big little tractor, buy the SA. Good Luck!!
Deutsch
02-27-1999 07:54:00
I also a Cub and a SA, plus a Case VAC. All very good tractors. With the belly blade on the Cub, most of my blade work is taken care of
Good Luck
