1936 or 37 w-30?
brad mersinger
02-26-1999 16:21:12
Need to know what year serial # WB11030 is and what color it should be.
Tim B
02-27-1999 10:07:09
 Re: 1936 or 37 w-30? in reply to brad mersinger, 02-26-1999 16:21:12
I own a 1936 f12 fs78243 which was built near the end of the year. I am getting ready to paint it right now. I brought this question up on the ATIS Farmall mailing list and got alot of response. Because it is a 36 you could paint it gray and be pretty sure that no one say much. I haven't heard that anybody knows for sure when the change took place.There also was talk that some of the dealers painted every tractor they had new and used red at the time so that they would stand out.
Alot of people said to pick the coler I liked best.
My tractor was red with gray underneath and I decided to go with gray so it looks like an older tractor which it is. good luck
Tim B.
C.Fitz
02-27-1999 00:43:33
You're tractor is definitely a 1936. Serial numbers for a W-30 ran from WB 10407 - 18683 in 1936. MY guess is yours should probably be gray. International switched to red in Nov. of 1936. Any original paint on the tractor now that would give you a clue or has it been repainted?
Martin Caldwell
02-27-1999 10:26:47
 Re: Re: 1936 or 37 w-30? in reply to C.Fitz, 02-27-1999 00:43:33
McCromick Deering's year of production ended in oct and new models started in nov. so if the serial number is '36 it should be gray.
Skip
02-26-1999 16:46:59
according to "the belt pulley " ser # book it is a "36". The colors changed from gay to red in 36 but I have never heard a serial # break.
Unsure
02-26-1999 16:26:51
Hi!Im Unsure.Really,Im unsure if the W30 would follow the F30 numbers or not,but if it does its a 1936.As for the color,Im UNSURE.Guy Fay would know if noone else does.
