Order Farmall Cub Parts Online
Starter problems on Cub
BUNKY
07-29-2001 17:32:18
we have a farmall cub and we are having problems with the starter it starts one time and not the next we have had the armatuer checked (growled) and the fields tested the check fine we put new brushes in the bushings are good what next??? also new battery can some one help????? ????
Bill VanHooser
07-29-2001 18:39:53
 Re: starter problems on Cub in reply to BUNKY, 07-29-2001 17:32:18
Just a long shot, but you may not be getting a good ground connection. Most of these tractors are grounded to the chassis through the battery box. Corrosion can prevent you from getting the necessary current to your cranking motor.
Bigdog
07-29-2001 17:57:11
Try checking the starter switch & connections. By the way, how long are you talking about between attempts to start?
BUNKY
07-30-2001 08:03:13
 Re: Re: starter problems on Cub in reply to Bigdog, 07-29-2001 17:57:11
well the tractor is just restored and it don't seem to matter how long in betwwen but we will check battery box and starter switch
