Update on H with no power
Andy
07-31-2001 13:07:42
I checked the compression as suggested and here are the results. no.1=100+ 2=75 3=100+ and 4=85. Do I need to check the valves next? What do I look for other than the gap? Thanks for your advice Andy in Ohio
Dan
07-31-2001 13:32:17
 Re: Update on H with no power in reply to Andy, 07-31-2001 13:07:42
Is that with engine warm? not sure what compression whould be on H but 2 are definitely too low. Squirt a little oil in 2 and 4 and recheck. If compression comes up is probably rings. I would also check valve gap but doubt that is the problem. When I had low compression in my SMTA it ended up being the camshaft that had a piece chipped off the end where it goes into the gear so the gear was loose. That hapens with tractors using a live pump but I wuld assume your H doesn't.
