Farmall M valves
Barry
08-03-2001 16:45:23
I would like to know the correct procedure to set the valves on my Farmall M It will idle but misses as soon as i give it some throtle i have rebuilt the carb and put new points and plugs and wires on it it seems to have some blow by though the air breather Iwould appreaciat any help i could get
The Red
08-04-2001 07:46:51
 Re: Farmall M valves in reply to Barry , 08-03-2001 16:45:23
Barry it is pretty straight forward. With the valve cover removed, the valve closest to the radiator is the exhaust. Once it opens and closes, the intake valve will follow immediately thereafter. Then slowly turn the engine until the first notch on the flywheel lines up with the timing mark. That piston is now on TDC compression stroke. I set the clearances at .018 with the engine cold. You will need a screwdriver and a half inch open end or box wrench. When you thighten the locking nut, hold the adjusting screw with your screwdriver to maintain the clearance. The second cylinder is intake, exhaust. Third is exhaust and intake. Fourth is intake exhaust. Repeat the same procedure on the other 3 cylinders.
If the missing doesn't go away, I would suspect your 2 advance springs in the distributor are weak and not advancing the timing enough when you speed the engine up.
Barry
08-04-2001 10:27:54
 Re: Re: Farmall M valves in reply to The Red, 08-04-2001 07:46:51
Thanks Red I followed your advice and it is running like a clock
Pawnee
08-06-2001 10:25:58
 Re: Re: Re: Farmall M valves in reply to Barry , 08-04-2001 10:27:54
Hi Barry. Did you adjust the valves or change the springs in the Dist. It is amazing how good these guys are. Thanks in adavance!
Barry
08-06-2001 14:37:24
 Re: Re: Re: Re: Farmall M valves in reply to Pawnee, 08-06-2001 10:25:58
I adjusted the valves,One of them on #3 cyl. had about a quarter inch play
