H or M wiring diagram
Bob
08-03-2001 20:05:20
Could someone email me a wiring diagram for a H or M?
The Red
08-04-2001 04:51:31
 Re: H or M wiring diagram in reply to Bob, 08-03-2001 20:05:20
Where is your voltage regulator or cutoff located?
Bob
08-04-2001 10:11:44
 Re: Re: H or M wiring diagram in reply to The Red, 08-04-2001 04:51:31
It's on the generator. Thanks-Bob
The Red With Pix
08-04-2001 10:48:40
 Re: Re: Re: H or M wiring diagram in reply to Bob, 08-04-2001 10:11:44
Bob punch below. The hot wire from the starter post goes on the left amp post with the gauge facing down. The right post has the coil wire, the wire to the light switch and the wire from the bat. terminal of the voltage regulator/cuttout. The very bottom wire is the wire from the field post on the generator.
The gen post on the regulator should be wired to the gen post on the generator. The field post on the regulator should be wired to the f post on the generator.
To polarize the generator, with the tractor shut down, momentarily jump a wire, to get a spark, between the bat post on the regulator to the gen post on the generator.
Good luck!
Bob
08-04-2001 10:59:44
 Re: Re: Re: Re: H or M wiring diagram in reply to The Red With Pix, 08-04-2001 10:48:40
Red-Thanks for replying. I couldn't get your pix to come up. Is the wiring any different with a mag? Thanks-Bob
The Red
08-04-2001 11:13:45
 Re: Re: Re: Re: Re: H or M wiring diagram in reply to Bob, 08-04-2001 10:59:44
I will email you a picture. Been having problems with Photopoint membership. They might have banned me from tagging.
The mag is completely separate from the ignition.
