C Touch Control
Bob Kinghorn
02-27-1999 15:33:19
The touch control system looses oil. No sign of it on the housing. It appears to come out of the bottom of the torque tube. Has anyone had this problem? Could the housing have a crack in the bottom causing the oil to get into the torque tube?
Mey (NH)
02-27-1999 16:00:10
 Re: C Touch Control in reply to Bob Kinghorn, 02-27-1999 15:33:19
Bob,
If the housing was cracked, I don't thing it would end up in the tube. It sounds like the pump is leaking into the crankcase. See if the engine oil level is above normal level, if so you have a rear engine seal leaking and since hy-tran is way thinner than engine oil it's coming through faster than regular oil would. So see if engine oil is mixxed in with the hy-tran at the tube. Just my thoughts. Mey
Curt Cooke
02-28-1999 15:56:16
 Re: Re: C Touch Control in reply to Mey (NH), 02-27-1999 16:00:10
It could also be you're loosing it at the spool valve O-rings or the bottom plate of the unit.
