International 300 backhoe tires
Brian M
08-18-2001 06:25:36
My International 300 Utility backhoe rear rim rusted around the valve and leaked most of the air and calcium. I removed tire, emptied remaining calcium, welded rim, replaced air without calcium, and remounted tire. Since there is the weight of the backhoe not sure tired has to be weighted. But now have one tire loaded and one not. Does anyone see a potential problem. Should I take on the truble to unload other tire or the expense to load the repaired tire.
Andy Martin
08-19-2001 11:58:18
 Re: International 300 backhoe tires in reply to Brian M, 08-18-2001 06:25:36
The biggest potential problem is a leak on the other tire damaging the other rim.
You make have trouble negotiating soft ground, bu tyou can always swing the hoe to the light side.
