Super M tune up failed
Brad
08-26-2001 20:31:53
I have been trying to tune my dad's super M and after points, condensor, cap, rotor, plug wires, and cleaning up the plugs, it still runs really rough. It seems to run smooth at slow idle, but runs really rough with any throtle or load ( as little load as driving in 4th or 5th gear). Anyone have any ideas as to what else I should check?
Thanks,
Brad
Brad
08-29-2001 10:33:53
 Re: Super M tune up failed in reply to Brad, 08-26-2001 20:31:53
Thanks to all !!! It turns out, plugs and wires did it in the end.
brad
gene b
08-28-2001 03:48:40
step one tune-up COMPRESSION CHECK new plugs dont make compression
sod
08-28-2001 11:07:20
 Re: Re: Super M tune up failed in reply to gene b, 08-28-2001 03:48:40
Apparently it has enough compression to start and run. It could have all the compression ever needed and if the plugs are bad, it still wouldn't run right. ( compression doesn't make sparks)
good luck
sod
dick
08-27-2001 07:26:38
Did you check the timing (using a timing light)? If that's OK, I'd adjust the main jet on the carb. (sounds as though you might be too lean) and try new plugs in that order.
Steve from MO.
08-27-2001 06:58:06
Points set too close would do this. I would try new plugs also. Then enrich the carburetor a little at a time if still needed.
Steve from MO.
08-27-2001 06:57:26
sod
08-27-2001 06:19:20
new plugs
good luck
sod
sod
08-27-2001 06:19:15
new plugs
good luck
sod
The Red
08-27-2001 04:28:24
In the electrical area, what sparkplugs are you using? Is this coil ignition or magneto system?
Chums5
08-26-2001 20:51:32
Adjust the air and fuel mix on carb.....
if it lopes at 1/2 throttle it a gasket problem on carb(sucking air)....only turn screws 1/8 to 1/4 at a time when running and should hear the difference....
Chums5
08-26-2001 20:50:46
Chums5
08-26-2001 20:49:53
