Havent started the H in 2 months
Brad
08-27-2001 13:33:18
I havent ran my H in about 2 months and as I was taking out the garbage I looked over at her and said mmmm.... I should start it up, just to make sure everything is okie doki. I opened the gas valve and then waited 5 seconds or so then pulled the ignition switch out and then pushed the starter button. then she cranked over 10 times or so and then I stopped and did it again and then VVVVRRRROOOOMMMM..... RRRUUUMMMM..... RRRUUUMMMMM.... RRRRUUUUMMMM..... I let her run for 10 minutes or so and then shut off the gas and then then shut off the ignition. Just gotta make sure that the old beast can still run y-know.
TomH
08-27-2001 16:39:38
 Re: Havent started the H in 2 months in reply to Brad, 08-27-2001 13:33:18
Those old tractors are like my dog, love to run.
Leave it on long enough to get up to operating temperature. The heat will drive off moisture that condenses in the oil.
The Red
08-27-2001 14:33:59
Brad retard your timing about 5 or 10 degrees. It should fire on the second or third crank.
