Spark Plugs for 47 M
Alabama
09-05-2001 13:13:46
I left my book at home and wanted to pick up some plugs on the way back to the house...can anyone tell me what type of plugs go in my M
I think Champion A15 but I am not certain
Thanks in Advance...
Todd
Jeff
09-06-2001 05:58:45
 Re: Spark Plugs for 47 M in reply to Alabama, 09-05-2001 13:13:46
Autolite 3116 - remember USE AUTOLITE!!!
The Red
09-05-2001 14:49:46
With today's unleaded 87 octane, 15s will probably be too cold and not fire well. Lately I have been using AC C86. If you like the Champion brand, use D21Y. Y stands for extended tip.
Denny Frisk
09-06-2001 06:20:45
 Re: Re: Spark Plugs for 47 M in reply to The Red, 09-05-2001 14:49:46
I don't run the Super H much, and all My old Kohler engines in My Cub Cadets have the unhardened valves and seats so I run a little leaded race gas with the no-lead I burn. They all seem to run Just like in the old days of 17 cent 87 Octane Leaded Regular! Wish I could say the same about ME!
The Red
09-06-2001 13:01:18
 Re: Re: Re: Spark Plugs for 47 M in reply to Denny Frisk, 09-06-2001 06:20:45
I use to have a coffee can full of failed D15Ys from the early 1990s. I never had any luck with them.
Denny Frisk
09-06-2001 14:59:24
 Re: Re: Re: Re: Spark Plugs for 47 M in reply to The Red, 09-06-2001 13:01:18
Dad put new A-C's in His '51 M and still couldn't get it to run worth a darn. He took a set of My 2 yr. old D-15Y's out of the Coffeecan, cleaned them up and I think They're still in the M. We had the spark plug discussion at ihcubcadet.com about a month ago. I guess the new Champion plugs are not as good as the old plugs were. Sounded like everyone was using Autolite. I had one break a porcelein in a new pickup 12 yrs ago. I think I'll use NGK's. Never broke a Champion like that!
Bama Binder
09-05-2001 14:03:59
As a general rule, the harder and hotter you work the tractor, the colder the plugs. I have used D15s with good success even in light duty applications, D21s are better for oil burners and light duty.
I think everyone agrees that with Champs, you just about have to go with D21s...for some reason the colder plugs foul and sometimes don't work well for no aparent reason.
Ludwig
09-05-2001 13:27:17
My Super M has D23's in it, Red usually suggests D21 for the H, I dunno what would be spec.
For what its worth my Super M usually runs really well and starts easy.
Denny Frisk
09-05-2001 14:18:04
 Re: Re: Spark Plugs for 47 M in reply to Ludwig, 09-05-2001 13:27:17
WOW!!! I didn't even know Champion made a plug that hot! All the lists I've seen show D-21 as hot as they go! My tired ol' Super H stll had a set of D-15Y's in it from many years ago. Starts & runs fine. Plugs probably have about 200 hrs on them. I used to put a new set in every fall when Dad farmed with it.
Ludwig
09-05-2001 14:40:41
 Re: Re: Re: Spark Plugs for 47 M in reply to Denny Frisk, 09-05-2001 14:18:04
These plugs are probably 10 years old.
I thought they might be a bit hot, I hadn't looked at them before, but I knew that Red said D21. Maybe I'll pick up a set of 21s and see what happens.
