Rear Squeeky On H!!!
1PWRFULH
09-05-2001 15:03:41
I was out driving the H about a week ago doing some loader work and noticed that in reverse it squeked a little bit on the rear end. Well I didnt worry much about it but while doing some work today I noticed the squeek got a lot worse. Here's the deal. It will squeek in reverse the most but it wont really squeek if your going down hill but as soon as it starts pulling some of its own weight she starts squeeking. It will do it in first gear if your going down a hill in first. I dont know what it could be. It is coming from the right side of the tractor only. I greased the rear axle and that didnt help at all. Seems as iff its coming from the axle or the brakes, somewhere around in there. Im afraid to much use it now. Also, while I was under looking and noticed oil leaking around the driveshaft on the transmission side. How hard is that seal to put in? All this started when I filled the tranny up with oil. What in the world could it be?? Thanks guys!
RC
1PWRFULH
09-05-2001 16:58:12
 Re: Rear Squeeky On H!!! in reply to 1PWRFULH, 09-05-2001 15:03:41
Heck, I got it! Im happy now! I guess I just didnt give the grease I put in enough time to work. I drove it all around but still I guess it takes a while. Its slicker than a wet cat now. One word of advise, If your rear end starts squeeking badly, grease up the axles. Thanks!
RC
Ludwig
09-06-2001 13:52:59
 Re: Re: Rear Squeeky On H!!! in reply to 1PWRFULH, 09-05-2001 16:58:12
Every year when I get the Super M out I grease everything good but the real axles always squeek a bit for the first few trips around the field. After everything gets a chance to warm up I usually give it one more hit of grease and everything goes fine.
kev@ia
09-05-2001 16:55:40
How close is the wheel clamp to the outer bearing? If the wheels are shoved in to much the wheel rocks on the key instead of clamping the axel properly. My 460 did this and when I switched the wheels around so that I could run in 30 inch rows the squeek went away, and I had bought the bearing to swap in.
Hope this helps.
