Oil in Air Cleaner for M
Alabama
09-07-2001 06:09:20
I took the fuel tank off my M...spent hours cleaning it out...Woo what a job! I then primed and installed it again. I took off the hood and grill and am working these over real well also. The engine runs real well and didn't burn any oil until I put the air cleaner oil in. I used 30 wt like the engine and only filled it to the fill line. I ran the tractor down to the horse stable (1/2 mile) and it started smoking (blue). I didn't disconnect the carb to see if oil had dripped down into it from the cleaner yet but I will do that this evening. Any Way, is it normal to burn oil from the cleaner on occation?
Redtractorman
09-07-2001 06:47:09
 Re: Oil in Air Cleaner for M in reply to Alabama, 09-07-2001 06:09:20
The only way it could draw oil out of the air cleaner bowl is if the top of the air cleaner assembly is plugged.
Jon with an M
09-07-2001 06:41:49
It should not draw the oil out of the cleaner. Is the filtering material still in the body of the cleaner? Is it clean? You can take the cleaner body off and soak it in kerosene to clean it.
Also, does it smoke now if you run it without oil in the cleaner? If it does the problem may not be related, do a compression check, you may have a stuck ring.
How long have you had the tractor? Have you put many hours of runtime on it?
My thoughts.
Pawnee
09-07-2001 07:38:32
 Re: Re: Oil in Air Cleaner for M in reply to Jon with an M, 09-07-2001 06:41:49
Hi Jon I have a super M with the oil bath air cleaner. I just recently cleaned it up but did not see any filtering material. The cap has a screen on the bottom but that is it. Should it have some type of filtering material and where would it be stuffed or located.
The Red
09-07-2001 06:37:09
No it shouldn't. Drop your oil level about 1/4" below the fill line and see if that takes care of the problem.
