SuperA w/delco12V Alt.
Bare
09-09-2001 14:54:15
I am trying to help my father install a delco internaly regulated alternator on our Super A tractor. we have it mounted but can't figure out where all the wires need to be hooked up. If anyone can tell me how it would be greatly appreciated. Thanks, Bare
Bob M w/diagram
09-09-2001 15:18:41
 Re: superA w/delco12V Alt. in reply to Bare, 09-09-2001 14:54:15
third party image
Here ya go Bare. Above is for a Super M but, a Super A is wired the same. ...Bob M
Marv
09-13-2001 15:18:51
 Re: Re: superA w/delco12V Alt. in reply to Bob M w/diagram, 09-09-2001 15:18:41
Bob you did a great job of drawing a diagram for a super A. I need help with a 454/2400A Int. There is a white and a red wire from a plug on the Alt. The white wire is open on the other side of the tractor, where is supposed to terminate.
Thanks Marv
Marv
09-13-2001 15:18:36
Thanks Marv
Bare
09-09-2001 15:38:46
Thank you so much for the diagram Bob M . Is it possible to substitute a voltmeter for the ammeter????? Thanks, Bare
Bob M
09-09-2001 20:33:36
 Re: Re: Re: superA w/delco12V Alt. in reply to Bare, 09-09-2001 15:38:46
Joe's right - you can use the existing ammeter "as is" on 12 volts. But a voltmeter will work fine too - wire it up like this: 1-Wire from the alternator BAT terminal direct to the starter switch. 2-Voltmeter "+" connect to the SWITCHED side of the ignition switch. 3-Voltmeter "-" connect to any good ground. ...Bob M
joe
09-09-2001 18:14:13
you do not need to change gauge. i didnt and bob said so as well. my gauge goes to 20. it starts with needle at edge but runs around 10 or so.
