Pulling oil pan on 1963 330 utility tractor
Allan
09-10-2001 08:04:05
My 330 utility tractor leaks around the oil pan bad and I was going to pull it and true it up and put on a new gasket.My question is do I have to pull the front axle and radius rod to get it out or is there enough room?Seeking advice
Steve
09-10-2001 13:53:23
 Re: pulling oil pan on 1963 330 utility tractor in reply to Allan , 09-10-2001 08:04:05
It can be done but it is a very tight fit. You may have problems with the gasket sliding. You will get a better fit/seal if you remove the steering.
Steve
