Fan assy. Farmall B
Big City Bob
09-10-2001 10:47:36
After cleaning and installing new gaskets, and repainting, the assembly. When I added oil back of the fan blades, where the little screw is, all the oil leaked out of the main shaft that mounts the fan to the motor. Then I looked at the manual, and there are no other gaskets that go on the main shaft according to the exploded view that I have. Is there a certain way to add the oil, and how much is needed? Any help wouldbe appreciated. Thanks, BCB
Haas
09-10-2001 13:35:34
 Re: Fan assy. Farmall B in reply to Big City Bob, 09-10-2001 10:47:36
Dave T is giving you good info. I'll add a little. There is no seal on the shaft. Centrifugal force keeps the oil at the outside of the hub when it is turning, so none comes out. You are likely overfilling the hub. Fill it like Dave says and you should be OK. It only holds a small amount.
Dave T
09-10-2001 11:14:43
Place fan assemble so screw is on the side. Fill until oil starts to come out the hole, then move to the down position and let out all the extra oil. There is a "stand pipe" inside that will keep all the oil from coming out. When it has drained excess, it is now at proper level.
