Brakes for International 1206
Brian
09-12-2001 09:39:59
I recently called about a 1206 that was selling for $5995. This is a 112 HP tractor so I figured it might be a good buy. I haven't seen it and the dealer wasn't sure of the hours but he did say it ran good but needed a brake job. I don't know it they are hydraulic, but can someone give me a price range that I would be looking at to fix the brakes. I don't want to put a lot more money into it. Thanks.
Ace Schrunk
09-12-2001 10:21:08
 Re: Brakes for International 1206 in reply to Brian, 09-12-2001 09:39:59
They are hyfraulic, can not give a price, not hard to work on. If they still use the same material that they did when the 1206 came out new with on the brake dics they are a very good brake, BUT THEY MUST BE BROKEN PROPERLY, if so they last a long time if not you might get 100 hrs.
the tractor vet
09-12-2001 19:15:00
 Re: Re: Brakes for International 1206 in reply to Ace Schrunk, 09-12-2001 10:21:08
The disc should cost you about 40 bucks a side plus you will need a seal and o/ring kit and i would recomend that you do install it , you might find that you may need some new return springs (4) per side and mybe even a few hard parts .
