NEED HELP with the ID of an IH carburetor !!!
Alberta Mike
09-15-2001 15:06:20
I've got a cast iron IH carburetor here. The small brass model number washer has the numbers 50981 DC on the top casting. It measures 2 3/8" center to center between the mounting holes. Any help you could give would be appreciated.
Michael Soldan
09-16-2001 19:03:10
 Re: NEED HELP with the ID of an IH carburetor !!! in reply to Alberta Mike, 09-15-2001 15:06:20
What the heck are you doing with an I-H carburetor??? Mike, it will fit an H , a W-4, H-V. O-4 , an O-S-4 ,a U-4 and a IU-4, thats basically H and W-4 and all the industrial applications used with the engines in them. I still haven't painted my H...I've been painting a 1953 McCormick 6' cultivator, hope to second coat on Monday and assemble it Tuesday..a nice little piece for my Farmall collection.Will give you a shout.
The Red. TADA!
09-15-2001 15:31:52
Mike you have a gasoline Farmall H carburetor!
Alberta Mike
09-15-2001 16:08:08
 Re: Re: NEED HELP with the ID of an IH carburetor !!! in reply to The Red. TADA!, 09-15-2001 15:31:52
Now, that was quick! I've had some reasonably fast answers before but nothing like yours. I've got a question about this carb that maybe you can answer for me. In the bottom half casting, there is the main brass fuel nozzle which points upwards at an angle and is screwed into the bottom casting. If you can imagine a line directly in line with that nozzle but below it at the bottom of the bowl, there is a brass fitting that appears to be 'threaded' (can't tell for sure) into the casting from below (along the same plane as the fuel nozzle). This fitting almost appears to be a plug of some type. It is sort of cone shaped and has a slot-head screwdriver slot into the top of the fitting. Funny thing is though, it turns in and turns out, but it doesn't tighten or loosen, it just keeps turning. There is a fibre washer between it and the casting. It almost feels like it's held in by an o-ring or something but it will not loosen out. Any guesses as to what this is or should be? Am I missing some part or is something wrong? Also, would that carb also be used on the W4 McCormicks? Appreciate your help.
Alberta Mike
09-15-2001 16:06:59
Now, that was quick! I've had some reasonably fast answers before but nothing like yours. I've got a question about this carb that maybe you can answer for me. In the bottom half casting, there is the main brass fuel nozzle which points upwards at an angle and is screwed into the bottom casting. If you can imagine a line directly in line with that nozzle but below it at the bottom of the bowl, there is a brass fitting that appears to be 'threaded' (can't tell for sure) into the casting from below (along the same plane as the fuel nozzle). This fitting almost appears to be a plug of some type. It is sort of cone shaped and has a slot-head screwdriver slot into the top of the fitting. Funny thing is though, it turns in and turns out, but it doesn't tighten or loosen, it just keeps turning. There is a fibre washer between it and the casting. It almost feels like it's held in by an o-ring or something but it will not loosen out. Any guesses as to what this is or should be? Am I missing some part or is something wrong? Appreciate your help.
JIM
09-15-2001 19:13:22
 Re: Re: Re: NEED HELP with the ID of an IH carburetor !!! in reply to Alberta Mike, 09-15-2001 16:06:59
That nut is what holds that fuel nozzel in place. It is treaded onto the nozzel. Hold down on nozzel as you untread nut and it should come out.
JIM
09-15-2001 19:13:14
