Front wheel hubs
Aaron
09-24-2001 09:23:09
I need to replace the front wheel hubs and bearings on my C. It is a narrow front. Does anyone know of a good place to find the hubs for a reasonable price? Also, where is a good safe jack point for lifting both front wheels.
Thanks.
John in Maryland
09-24-2001 14:32:55
 Re: Front wheel hubs in reply to Aaron, 09-24-2001 09:23:09
Just change one wheel at a time. Drive one wheel up on a block of wood. Also, try to get the numbers off of the bearings and try to get them from napa or autozone or whatever-just did mine and saved about $20 per wheel by matching the bearings.
Aaron
09-24-2001 13:28:58
The reason that I want to replace them is that one of the hubs is broken badly.
Bart
09-25-2001 14:50:25
 Re: Re: Front wheel hubs in reply to Aaron, 09-24-2001 13:28:58
Aaron, Try the classified ads, left margin, this page. Someone will have spare hubs for sale. I have had good luck with classified ads.
Bill Smith
09-24-2001 11:29:52
What is wrong with your hubs? Unless they are broken or the bearing races have spun there shouldn't be anything wrong with them. The bearing races you should be able to replace. You simply pound them out or press them out and most generally the new races will come with new bearings. If they don't you should be able to get them seperately.
Bob M
09-24-2001 10:49:11
Aaron - You can safely jack the front of your tractor by locating a bottle jack under the clutch housing. Be sure to block both rear wheels and set the brakes however!
Bearing/seals are industry standard. Get the numbers off the old parts and have your local bearing house cross them for you - they'll be cheaper there than at a C-IH dealer.
