Hydraulic Question on M Belly
Alabama
09-24-2001 11:02:09
Can I hook up multiple hydraulic lines to the belly pump. Maybe split the existing hydraulic line into two lines via a new spool? I would like to put a front end loader on it but would also like to use hydraulics to dump and lift the bucket as well.
Thanks in advance.
Haas
09-24-2001 14:30:36
 Re: Hydraulic Question on M Belly in reply to Alabama, 09-24-2001 11:02:09
You can put as many lines and spool valves on the belly pump as you want. Just remember it has limited flow and pressure capability. Only generates about 800 psi. Not sure of the flow. To use spool valves, run a line from the lift all output to your spool valve inlet and run the return from the spool valve into the fill port of the lift all. The fill port is on top in front of the belt pulley. Then when you wnat to use your spool valves, lock the lift all in the lift position so that fluid flows through the spool valve all the time.
