IH 350 utility leak
brian
10-01-2001 14:19:03
Thanks for all the information I have gleaned from this site. I purchased a 350 utility recently for wildlife food plots and to mow CRP. Tractor runs great but recently I discovered the throttle linkage had jumped out of place. I think it was rubbing on the power steering column. Under any hydralic load the fluid seems to be running out of a plug on the upper end of the steering column, I got to it & tightened it as best I could but still leaking- pretty sure from the plug. Anyone else had this problem? Can I use something on the threads like teflon tape? What happens if I lose too much fluid? Any input appreciated. Thanks,
Brian
