1953 FARMALL SUPER (M)
BUD BARENIE
10-01-2001 18:03:43
I HAVE A 1953 S M. JUST STARTED STOCK PULLING.
WOULD LIKE TO REBUILD ENGINE THIS WINTER. NEED HELP ON WHERE TO FIND AFTERMARKET REBUILD KITS, WOULD LIKE TO INCRESE HORSEPOWER @ TORQUE !!!
ALSO HAVE AN M@W GOVENOR ON THE TRACTOR, I DON'T BELIEVE THE GOVENOR IS WORKING PROPERLY. WHEN PULLING, SEEMS THE GOVENOR IS NOT KICKING IN. BOUGHT THE TTACTOR OUT OF A FIELD, WAS IN A BARN FIRE,CARB WAS REBUILT FROM ORIGINAL TOP AND A 706
BOTTOM, WHEN I ADJUST THE FUEL JET IT MAKES NO DIFFERENCE IN HOW THE MOTOR SOUNDS, NEED ADVICE ON GOOD CARB, IGINITION AND ENGINE PART'S PEOPLE
THANK-YOU !!
Dale13
10-02-2001 11:53:41
 Re: 1953 FARMALL SUPER (M) in reply to BUD BARENIE, 10-01-2001 18:03:43
Search the archives here for info on [more power],etc. You can go to Denny's for your parts if you want I NEVER WILL. For IH parts most parts stores ion a farming area will have a line of kits. I pull with mine and have had a good year in the stock class,I have the original head and carb and manifold. And believe me there is no such thing as unbeatable!!
Dale13
10-02-2001 11:53:33
BUD BARENIE
10-02-2001 14:55:09
 Re: Re: 1953 FARMALL SUPER (M) in reply to Dale13, 10-02-2001 11:53:33
WHAT'S THER PROBLEM WITH DENNY'S CARB SHOP HEARD OTHER COMPLAINT'S . JUST STARTED PULLING AND DON'T WANT TO WASTE MONEY ON ENGINE REBUILD KIT'S THAT DON'T WORK !! DENNY'S SENDING A CATALOG ON DIFFERENT ITEM'S, SELF EMPLOVED DON'T HAVE ALOT OF
TIME, BUT I,VE BEEN TO THREE PULLES, AND HAVE HAD MY FIRST, FIRST PLACE AND AM ALLWAYS FINISHING IN THE TOP 8 (CLASS) 5500-6500 AND 6500-7500 I'VE GOT THE MAJOR BUG BITE HERE !!! JUST LOVE THE SPORT !!! THANK'S FOR THE REPLY ALSO WHAT DO YOU THINK ABOUT 23DCEGREE FIRESTONES, CURRENTLY RUNNING 15.5-38 45DEDGREE FIRESTONE
Dick
10-01-2001 18:38:08
I was told that you can put in a 450 manifold, 450 crankshaft, plane the head, and put in a high alitude kit for a 450, pullout the hyd. belly pump,then you'll have to put a gear reduction starter drive, you'll have an unbeatitable tractor (Super "M").. my 2 cents
Denny Frisk
10-02-2001 05:56:39
 Re: Re: 1953 FARMALL SUPER (M) in reply to Dick, 10-01-2001 18:38:08
I think the crankshaft in an M, SM, 400 & 450 are all the same, all 5-1/4" stroke. M was 3-7/8" bore, SM & 400 4" bore & 450 4-1/8" bore. 450 crank may be modified for more strength due to 13% more displacement.
