I NEED HELP!!!! Please!!!
Bigtime299
10-02-2001 16:48:13
I have just purchased a Super A, and have posted some questions before. When the tractor was bought, I had no implements. Since then, I have added a double gang disk harrow. At first, the hydrolics lifted it fine, no hesitation at all. Now, nothing. It won't move it 2 inches. When I unhook from it, it works great. I never checked the resevoir when I first got it, could it be as simple as being low? I have no leaks, nowhere. I have looked this thing over from top to bottom, and find nothing. If it is low, where do I get what to go in it? I am feeling pretty low right now, I had hoped to be turning my land for the fall in a couple weeks, now, I don't know. I hope someone can point me in the right direction.
BOB(PA)
10-02-2001 18:27:22
 Re: I NEED HELP!!!! Please!!! in reply to Bigtime299, 10-02-2001 16:48:13
hey bigtime299 use case HY-TRAN ULTRA fliud
when sitting on tractor the fill plug is to the left side of hydralic unit near the top is a big nut 1" or better that is your fill plug.make sure you have your lift all levers pulled towards you when sitting on tractor.then fill resavor to about 1/2" of bottom of hole.MUST do this correct or you will have fliud all over the place!!!!!.THE REASON IS the cylinders are in there retracted state. when you move lift levers forward the fliud drops down in the resavor. BOB
BOB(PA)
10-02-2001 18:31:55
 Re: Re: I NEED HELP!!!! Please!!! in reply to BOB(PA), 10-02-2001 18:27:22
P.S. almost forgot if dont have any leaks PLEASE check your engine oil level.when front pump seal leaks it goes in the engine oil
Glenn(WV)
10-03-2001 05:29:39
 Re: Re: Re: I NEED HELP!!!! Please!!! in reply to BOB(PA), 10-02-2001 18:31:55
I agree with Bob. Check your engine oil level. If it is high, a seal in the pump has failed.
doug vose
10-02-2001 17:38:33
probly just needs some fluid. dont know what kind it takes, maybe somebody else will be able to tell you. in my Cub's hydrualic lift i use hydrualic/transmission fluid(something like that), works fine. thats what i have to use in my *#!% 9N(explicit language deleted), because it uses the same fluid in the transmission as the hydrualic system.
