Loader for Super A or 100
Bruce
10-02-2001 23:44:36
I can buy a loader for under $500 for my '56 Farmall 100. The owner says it's an IH accessory or an aftermarket accessory. It is red, heavy and old. (PTO driven pump and round tank are one unit)
Are these things any good?
This is a front end loader with lots of "farmer's welds" on it.
Appreciate the expertise on this website.
Bruce from Kalama, WA
Thomas C. Olson
10-07-2001 21:21:29
 Re: Loader for Super A or 100 in reply to Bruce, 10-02-2001 23:44:36
Bruce,
I have a '47 Super A that I was able to get a loader for years ago made by a company called Henderson. The factory tag is riveted on the right side lift arm. It also used the Char-Lynn pto pump. The lift cylinders and rods were badly rusted so I bought new ones. I'm now in the process of installing a diverter block and separate control valve in order to have live hydraulics.
Tom Olson
Vern
10-03-2001 22:08:31
Wagner built a loader for the Super A.
Brian
10-03-2001 18:40:14
Oh just one more comment.....
We have another Super A with the same bucket sytem, however because it has hydraulics already, it only has a valve.
Anyway... the unit we have has a sticker on it which says Char-Lynn. Char-Lynne makes hydraulic valves etc ( currently owned by parker-hannifin), I am not sure if they made the whole unit, or just the hydraulics.
Also check to make sure the cylinders are ok, they used leather seals incidently. if they are not, you can get new cylinders, however they are going to be costly. I know of a souce to get really cheap cylinders if you need to.
Brian.
brian
10-03-2001 18:29:48
It sounds like a unit we have on one of our A's, these units work pretty good, the fact that the PTO has to be engaged in order to use it is a pain in the !#%R$ but liveable. One thing to check is that the lever (one side) is unstuck. On ours the lever was stuck and to be honest has been apart for about ten years. The pump and valve is all one unit, and I still haven't figured out how to get it unstuck.
If your tractor has hydraulics I would recommend "T" into the pressure line.
The loaders are handy, but they aren't very big.
Haas
10-03-2001 06:50:22
If it is a one arm IH loader, I would buy it. The one arm IH loaders are in demand and are not very common. In good condition they often sell for more than $1000. Don't know how they work, never used one. I used to have a front blade on a 140, so based on that, I would say the loader would be good for light duty work is soft dirt or other soft stuff.
Glenn(WV)
10-03-2001 07:33:02
 Re: Re: Loader for Super A or 100 in reply to Haas, 10-03-2001 06:50:22
I've yet to see a model 1000 one-armed loader going for under $2000. They are pricey!!
Bruce
10-03-2001 11:24:12
 Re: Re: Re: Loader for Super A or 100 in reply to Glenn(WV), 10-03-2001 07:33:02
The loader is a "conventional" two armed loader with the pivot brackets bolting to the flywheel housing and trans tunnel in two spots. There is one lift cylinder per side and the bucket has a manual trip. The hydraulics are controlled by a long lever that sticks out of the round hydraulic reservoir. What think you now??
Bruce
Glenn(WV)
10-03-2001 20:12:31
 Re: Re: Re: Re: Loader for Super A or 100 in reply to Bruce , 10-03-2001 11:24:12
I once saw an old ad for a two-arm aftermarket loader. It was designed for the 100, it was sold as an IH-approved accessory, and if memory serves, it was similar to the one you own. Unfortunately, I don't remember who made it. :-(
Haas
10-03-2001 12:56:25
I think it is probably and aftermarket loader, not an IH. Don't have and idea of the value.
