Will a 400 hyd pump fit an M
Bama Tide
10-03-2001 11:59:01
Will a live hyd pump fit an M, and what mods need to be made?
Jim
10-03-2001 14:26:17
 Re: will a 400 hyd pump fit an M in reply to Bama Tide, 10-03-2001 11:59:01
The last of the M's have the same front covers as the SM and 400's. What year is your M?
Bama Tide
10-03-2001 14:28:07
 Re: Re: will a 400 hyd pump fit an M in reply to Jim, 10-03-2001 14:26:17
Year of M in question is 1947.
Ace Schrunk
10-03-2001 13:56:47
Hydraulic pump SM 400 450 WILL NOT fit M bolt parttern not the same.
RedM
10-03-2001 12:54:23
Try Jim Campbell Lawrenceburg, Tn if you are interested in buying live hydralic system for M.The last time I was there a few weeks ago he had several complete systems still on tractors.HE is listed in some of the salvage yard lists I don,t have his phone number.
RedM
10-03-2001 13:29:19
 Re: Re: will a 400 hyd pump fit an M in reply to RedM, 10-03-2001 12:54:23
Yes the 400 pump will bolt on SuperM and I suppose a M.
jmyt_47
10-03-2001 12:50:21
You'll probably need the front timing gear cover and plate that mounts to the engine block. You may also need the timing gears off the 400- I think they are a stronger design to handle the hydraulic pump.
