NEED ADVICE, about a clutch change in a 48 C
Billy
10-08-2001 20:03:42
I want to replace the old worn out clutch in my uncles Farmall C. He does not know that I plan on doing this, he is sick and in the hospital as of this time. My other uncle said that he will help me do this work, but we want to be sure that the parts will innerchange. So here is my question:
Will a clutch and pressure plate assembly that was removed from a Farmall Super C, bolt up correctly to the flywheel and work alright in my uncle's regular Farmall C ?
I am not sure if they are interchangeable or not.
Any information would be of a great help.
Thank You Very Much
Farmer Bob
10-08-2001 21:22:14
 Re: NEED ADVICE, about a clutch change in a 48 C in reply to Billy, 10-08-2001 20:03:42
Billy, The only thing I'm unsure of is if you are replacing an Auburn assembly with a Rockford assembly it may or may not work. Seems like they should interchange as the flywheel is the same for both. Other than that, they should bolt right up. Make sure you check the old clutch release bearing while you're in there with the tractor split. Also check the clutch shaft pilot bushing that fits into the end of the crankshaft. Good luck.//FB
