Farmall 450 brakes and trans fluid
B. Leins
10-09-2001 18:29:26
What`s with sae10 oil and additive in the trans?Seems like foamy milk when hot. Also even new disc brakes don`t work too good. What am I doing wrong? Thanks for the help.
Red Rider
10-09-2001 20:17:32
 Re: Farmall 450 brakes and trans fluid in reply to B. Leins, 10-09-2001 18:29:26
Your brake problem is most likely just normal ware. To correct this you need have brake contact surfaces machined about 5 to 10 thousands to clean them up you also need to have the outer brake housing mating surface turned down to counter act for the ware. On my 4 tractors I took the amount of the machined surfaces plus another 40 thousands. Those actuators need to be almost straight when in the normal position. Get you a small wire brust for your drill and polish the ball bearing socks and ramps. Those balls are hard to polish but if you take you time it can be done. Replace any defective part and your brakes will work like a charm. With very little pressure I can lock mine on pavement.
Jon
10-09-2001 19:29:22
Use Hy-Tran from your CaseIH dealer in the Hydraulics, PTO, and tranny. Put in new brake springs and balls and make sure everything is cleaned up good. Also adjust them after putting everything back together
