Motor oil in crankcase in Farmall m
abane
10-09-2001 19:16:01
How does motor oil get into the crankcase of a Farmall M and what do you have to do to correct this.
Gary
10-10-2001 04:17:13
 Re: Motor oil in crankcase in Farmall m in reply to abane, 10-09-2001 19:16:01
I have a number of old tractors of different vintage.Most of them have oil in the crank-case. The ones that DO have oil in there seem to out last the ones that don't. Even at todays oil prices it makes economic sense to lubricate the crankshaft since the cost of bearings and gaskets are much more than that of oil. Hope this is helpful.
Dick Davis
10-10-2001 07:01:25
 Re: Re: Motor oil in crankcase in Farmall m in reply to Gary, 10-10-2001 04:17:13
Gary, Neat answer.
Red Rider
10-09-2001 20:06:31
Just ahead of the distributor is a 3 inch diameter wingnut type cap. Thats how motor oil gets into the crank case. Now what you mean by correcting this I'm not sure. If you don't want oil in the crank case you can either drain whats in there or don't put any in.
I aint touching this one...LOL
10-09-2001 20:02:02
sammy the RED
big al
10-09-2001 19:57:36
Do you mean how do you put oil in it?
Bill J
10-09-2001 19:40:56
The crankcase is where oil belongs,do you need to know how to add oil, or how to drain oil, or how much oil the crankcase holds?BillJ
a bane
10-10-2001 04:33:55
 Re: Re: Motor oil in crankcase in Farmall m in reply to Bill J, 10-09-2001 19:40:56
I'M SORRY ABOUT ALL THE CONFUSION,I MEAN I PUT OIL INTO THE CRANKCASE AND THEN BY SOME MEANS ITS GETTING BACK IN THE GEAR OIL. I CAN'T KEEP OIL IN THE CRANKCASE!
The Red
10-10-2001 05:05:29
 Re: Re: Re: Motor oil in crankcase in Farmall m in reply to a bane, 10-10-2001 04:33:55
If you are speaking of engine oil getting into the transmission, that is not possible. You will have to be more clear. Do you by chance have a live hydraulic pump?
a bane
10-10-2001 09:04:56
 Re: Re: Re: Re: Motor oil in crankcase in Farmall m in reply to The Red, 10-10-2001 05:05:29
Red, could it get out of the motor and if it could where would it go?
JDM
10-10-2001 15:43:08
 Re: Re: Re: Re: Re: Motor oil in crankcase in Farmall m in reply to a bane, 10-10-2001 09:04:56
In all seriousness,sounds like you have a rear seal that is leaking.Im guessing but by "getting in gear oil"You mean that it is leaking from where the belly pump is,right?the only way oil can come out of the engine is if you drain it from the bottom of the oil pan,you have a seal or gasket leaking,or as suggested youre smoking like a freight train!There is no way that oil from the engine is getting in the gear box!
ff316
10-10-2001 12:12:57
Out the stack. Does it smoke like a freight train?
a bane
10-10-2001 16:53:34
 Re: Re: Re: Re: Re: Re: Motor oil in crankcase in Farmall m in reply to ff316, 10-10-2001 12:12:57
never smokes --
