Overunning clutch
54cub
10-13-2001 11:23:16
I have tried several places for an overunning coupler/clutch for my 54 cub. Because (as I am sure you know) it is reverse rotation, and, is 1 inch diameter, I have struck out.
Any ideas??
Haas
10-13-2001 17:33:38
 Re: overunning clutch in reply to 54cub, 10-13-2001 11:23:16
Wonder what you are going to pull with the Cub that requires an over running clutch??? The IH 42 inch one blade mowers that fit the Cub had a built in clutch. No standard heavy implements will work because of the reverse rotation. Can't imagine hooking the Cub to anything very heavy anyway.
54Cub
10-14-2001 04:25:13
 Re: Re: overunning clutch in reply to Haas, 10-13-2001 17:33:38
The implement I'd like to use the clutch with is an International C-3 belly mount three blade mower. It works great "as is", I just thought a clutch would get rid of that 6-8 foot increase in stopping distance.
Haas
10-14-2001 05:44:48
 Re: Re: Re: overunning clutch in reply to 54Cub, 10-14-2001 04:25:13
Yes, the overrunning clutch would help reduce the stopping distance. I doubt you are going to find one however. If you do, it will be expensive because it will be a specialty item.
