HOW DO I KNOW?
BILL
10-14-2001 17:25:33
I have a farmall tractor...
I can not find any serial numbers on the tractor except for motor or pto housing. All the info I have is on the cowling and it says,IH McCormick Farmall A Cultivision. Is this tractor a Super A ?
Where would I find the serial numbers?
Any info would be greatly appreciated.
Jim Becker
10-15-2001 09:53:22
 Re: HOW DO I KNOW? in reply to BILL, 10-14-2001 17:25:33
Most A and Super A tractors had the serial plate on the seat mount as others described. Very early A models had the plate on the guard below the pedals. The whole guard may be gone. All but the last A engine numbers were the same as the serial number (if it has the original engine). The engine number is stamped into a machined boss at the top of the engine block, right side, near the front.
Chris B.
10-14-2001 21:26:38
Short of a serial tag, the hydraulics are your best indicator of the model type. However, I don't believe that Supers were marked as Cultivision tractors.
Chris B.
Andy Martin
10-14-2001 19:08:45
If it is a Super A it will most likely have a hydraulic lift under the gas tank. If not, probably not. The decals indicate it is an A.
The serial number plate is on the right side of the left seat support and is only obvious after you've seen it.
Dave G
10-14-2001 17:33:26
Look on the left seat frame, there should be a metal serial Plate rivets to the frame.
