Sleeve seals
AGR538
10-15-2001 14:53:47
Finally got my motor unstuck on a 1940 H I bought. For some reason the #2 cylinder was full of rust. It did not come from the cylinder wall or piston but somehow had suck about a 1/2 inch or more of just pure rust. That was the stuck piston. When I tried to turn the engine the sleeve came up with the piston. Do the H's have sleeve seals? If they do not, can I just push the sleeve back in place and will it keep water out of the oil pan?
Gary
10-15-2001 17:00:54
 Re: sleeve seals in reply to AGR538, 10-15-2001 14:53:47
The H (C152) has what I call a dry-sleeve engine. You should be able to put it right back in. If it were mine, I would clean it out good,(hone the sleeve), and clean the cylinder in the block. I would hone that hole very little if any but make sure the land at the top is really clean (same with the top of the liner)so it will go into the block to the right height. The fit between the liner and the port in the block need to fit well in order for the heat to transfer well. If it fits too loosely,you can smear a minute amount of valve grinding compound on it in order to "snug" it up. This will not only make a tight fit, it will assist in heat transfer.
