Farmall B Culti-vision
B.Rivard
03-07-1999 13:09:18
Is it possible to determine a production year from things other than a serial number? The tractor does not have a serial plate or stamped number on the left side of the transmission/bell housing. I checked the serial number data and it appears that Models A,AV,B,BV used the same sequence from 1939 to 1947. Also what is the price range of this tractor? It is in fair shape with a Woods belly mower.
Thanks
Bill
mark
03-07-1999 19:54:51
 Re: Farmall B Culti-vision in reply to B.Rivard, 03-07-1999 13:09:18
on the b's there may be a date stamp on the trans mission casting housing just above the floorboard on the rt side of the tractor. it will be at a 45 degree angle. it that doesn't work try the letter coded system. seems IHC started coding their castings in 1931 with the letter a, 32 was a b 33 a c and so on down the alphabet. you can figure the yr model pretty close. works on all the lettered series tractors too. hope this helps.
Stan(VA).
03-07-1999 14:17:38
B's had the plate either in front of the foot pedals, or on the left seat support.
Stan.
