806 Shifting Problems
911-806
10-24-2001 08:17:06
My problem is two fold, first of, and I believe this is a linkage adjustment problem, my 806 falls out of low range while its in operation. Secondly it makes a "high speed" grinding noise when it is in high range. the noise occurs just after the clutch is released. I have not ran the tractor for any time in the high range. I just replaced the range selector cam under the transmission cover. Any help would be appreciated
NEAL S.
10-24-2001 11:45:45
 Re: 806 Shifting Problems in reply to 911-806, 10-24-2001 08:17:06
I would believe that the roller or bushing that fits on the pin on your shift fork either broke was not installed or the cam spring under the shift cover is broke. with floor pan removed see if their is freedom on the shift lever with link pin removed. Good luck.
