Possessed PTO
Alabama IH
10-24-2001 18:17:52
The PTO shafts on my '48 Super A have begun to turn slowly even when the PTO is not engaged. I have added new gear lube and even thinned it a bit by adding a portion of lighter viscosity oil. I don't think it is tempurature related as it happens even in 80 degree weather. Why has my PTO become possessed?
J.D. Humm
10-25-2001 02:28:00
 Re: Possessed PTO in reply to Alabama IH, 10-24-2001 18:17:52
For what it's worth-I've seen many older Farmalls do the same thing. ( The ones without live power ).
Jim
10-24-2001 21:25:34
There is a pilot bushing in the countershaft and it might be galling to the pilot shaft of the PTO.
Kipp
10-24-2001 19:51:55
I have an IH Cub Lo-boy (same as farmall cub, only lower) that does the same thing. As a heavy equipment tech student, my guess is that the oil although it is a lube, creates a micro-thin layer between the two shafts where they meet, much like the crank bearings in a car. (you know how they are really close to each other?) that would create enough friction to turn the shaft. kinda like a fluid coupler. Hope this helps!! Any other questions you have on your tractor, feel free to email me. Kippster
gene b
10-24-2001 19:06:09
nothing to worry about when it gets good and warm it will stop you should be up north when it gets cold you would hear a lot of funny noises till the machine gets warmed
Steven
10-24-2001 18:50:56
My A does it too. Also I had an M that did the same thing. Something just has a little friction inside there to keep things moving.
Steven
Its getting close to Halloween :)
10-24-2001 18:41:39
10-24-2001 18:41:48
